Multiple upload files
Can I upload multiple files at once with Digital file 2?
Thank you.
Thank you.
Yes you can,
Basically you just need to add additional file fields to your form. and bind them accordingly.
I just did a multiple field with 10 file fields and 10 text fields. following this tutorial, dfp_da_insert_update_ht.pdf
keep in mind your servers maximum file upload setting though with multiple file fields its easy to exceed it.
