wizard reenter
Hi i was wondering if anyone has the same issue of once applying promaps i cannot edit it or wizard-reenter it as it says,
thanks in advance
Regards
jamil
thanks in advance
Regards
jamil
Hi Jamil
I have noticed that this can be a bit of a pain if you click near the edge of the palceholder it doesn't seem to always work. I have got into the habit of clicking on the word Google in the placeholder banner and it seem to work everytime when I do this.
Best regards
Jon
If you are looking in the code or split view it is the div that must be selected to get the edit option to appear in the property inspector.
<div id="wagmp_map_4" style="width: 300px; height: 300px;">
thanks eric ill take a look and come back to you shortly, nice to know people are out there to help!!!
No problem, you are very welcome. Let us know if the problem persists.
Hi guys i have clicked on the div tag as advised and also the logo on the google maps - for some strange reason i cannot edit the map- very frustrating!
i must tell you that i have put the pro maps in the spry tabbed widget - it works fine at home but i have to do this at work as i am looking after the project at work - if i try to delete the pro maps and re-enter the serial number it says that i need to buy a new licencse??? well i only bought it when i was at home becuase it was one weekend and now i dont see the need to purhase it twice just becuase im at work. please help
regards
jamil
Hi guys i thought id just post this so that your precious time is not wasted.
when i take the pro maps div out of the spry tabbed widget the wizard re-enter becomes live!
however its still asking for a serial number which when i input says i need a new licencse
thanks to all again for the support
jamil
Glad to hear that you got it working outside of the spry, I would suggest doing your edits like this then put the map back in the spry as a final step.
As for the activation if you have too many you can reset them by logging into the site and visiting your download area. After you do this you should be able to activate the tool two times, one for your home and one for the office.
thanks jon ill take a look and come back to you shortly, nice to know people are out there to help!!!
