Drop down List box filter.
Thread begun 11/14/2009 8:18 pm by shelpat393784 | Last modified 11/16/2009 10:47 am by Eric Mittman | 2659 views | 1 replies |
shelpat393784
I did not see a tutorial on how to filter data with a dropdown list box. Is this posible.
Thank you.
One way to do this would be by using client side js to redirect to this same chart page but with the new parameters you would like the chart displayed with.
You would want to make sure that have your chart set to take parameters from the querystring, then in your select list you would send the user to this page with the different querystring parameters that that will give them the chart they have selected.
This is not a feature of Dynamic Web Charts that is directly supported but if you can alter the querystring variables with a select list then you would get the different chart data to show.
