little trick (need help)
Thread began 11/14/2009 2:56 pm by drmovi393161 | Last modified 11/16/2009 9:54 am by Jason Byrnes | 937 views | 1 replies |
drmovi393161
hi
i'm working on an event managment system using webassist
i've 2 tables courses & categories
courses table have many fields including catid field
categories table have catid field & catname field
so the link between the tow tables is the value in catid field
i've set the course results,search,update and delete for the course table using dataassist
but i need to connect the two tables so to show the catname in the courseresult page instead of catid
thanks
Use a JOIN Query to get the results from both tables:
SELECT courses.*, categories.catname
FROM courses
INNER JOIN categories
ON courses.catid = categories.catid
This will return all column from the courses table and the related catname from the categories table.
See the following for more on join queries:
sql_join.asp
