Will not pull back data from MySQL
Thread began 11/14/2009 11:17 am by Paul | Last modified 11/15/2009 9:49 pm by Roland Rogers | 1025 views | 1 replies |
PaulBeta Tester
Used Data Assist to create an update page which also contains html editor.
When I open this page after searching for a record, the form is populated with all field data apart from the textarea field, or at least was the textarea filed before i placed html editor in the same page.
Any ideas?
Thanks, Paul
Roland Rogers
Try to add it again
Go to the text area that is now the HTML Editor field and select it. In Properties there should be an "Edit" button. Select it and then add the datasource from there in the Initial Value field.
HTH
