menu writer out to delete selections insert box
While trying out the application I created several menu that I no longer use nor do I want them to show up in the list . How do I delet menu out of the insert menu box.
Thank You.
Thank You.
You can manage your preset menu's with the preset or layout manager depending on the version you are using. You can find this at Insert > WebAssist in DW. You will see a list of the presets and you can add, remove, import, or export these presets.
