javascript error WA_checkMySerialNumber is not defined
Thread begun 11/13/2009 1:26 pm by jkw133706 | Last modified 11/19/2009 2:38 pm by Jimmy Wu | 2494 views | 3 replies |
jkw133706
I get this error when I try to add the server behavior... create dynamic array:
(see screenshot attached)
I have already tried reinstalling the latest extension and deleting the MacFileCache file
Thanks for your help! I'm using Dreamweaver CS4 on a Mac OSX 10.5.8.
Jimmy Wu
I apologize for this. For our last update we missed updating the function call for ASP. If you go into that file and change line 22 from:
if (!WA_checkMySerialNumber(false, true)) {
if (!doSerialCheck()) {
you shouldn't run into this issue again.
Also make sure to change it in the ASP_js directory as well.
jkw133706
can't find the file on my hard drive
There is no WA Dynamic Dropdowns in the ASP_VBS directory and the extension IS installed. ??? The directory does exist in the /Library/Applications Support/Adobe/DreamweaverCS4/en_US/Configuration/ServerBehaviors/ASP_vbs/WA Dynamic Dropdowns. Why is the path different that that in the warning box?
I edited the files (once I found them) and that seems to have fixed the problem, thanks!
Jimmy Wu
There is a configuration folder for the built in dreamweaver functionality that is checked first for the file. If you install any extensions, there is a different configuration folder that the files get installed at. The error messages will refer to the first configuration folder, so the path referred to is different.
