Buggy extension
Thread began 11/13/2009 11:31 am by info4753 | Last modified 11/17/2009 10:12 pm by Dani Chankhour | 1348 views | 3 replies |
info4753
Buggy extension
I installed the new version and it's causing trouble after trouble. Ether the updated text area field isn't related any more (update is not working anymore) or the skin is changing to something like "Page (custom)".
I lost a full working day with the update. :-(
Dani Chankhour
On your update page, make sure that the name of the HTML editor is what is being used in the Update Server Behavior (the query).
info4753
Originally Said By: Dani Chankhour
This is a joke. I have to change everything by hand. Maybe I missed the note "incompatible with Adobe's ADDT" when I bought he update...
Dani Chankhour
There is no reason for HTML editor to be compatible or incompatible to Adobe ADDT.
The DataAssist update should still work with HTML Editor, as long as you have the same instance name.
Could you please copy and past the DFP Server behavior code and the DataAssist update server behavior code in a text file and attache it so i can see what is causing the issue.
If you could also explain a little bit more about the error you are getting (if any) or the result that you are seeing on the page.
