Cant use Dreamweaver Editor
I am walking through the UEmail wizard and I get to the body tab and I click on the DW editor button and I get the following pop-up window error:
the following JavaScript error(s) occurred: In file file:///Macintosh HD/Applications/Adobe Dreamweaver CS3/Configuration/Inspectors/WAUEInsp.html: The dreamweaver.createDocument() and dreamweaver.openDocument() functions can only be called by a command or property inspector, not an object or behaviour.
I click ok and the wizard goes away and I notice that it creates the following file
register_WAUE_HTML_WA_Universal_Email_3.php (my 3rd attempt)
I saw another post that said delete all mac caches.. i did this and restarted but am still getting the error.. I need to use the DW Editor for the body somI can bind the form fields to the email. Is there another way to do this other than using the DW Editor?
thanks for any help
Scott
****UPDATE****
I went into The register_WAUE_HTML_WA_Universal_Email_3.php file and added the email text and form bindings in this file then I saved it and after saving I clicked on it again and the wizard re-opened with all of the correct info in the body tag.. I then clicked ok and things seem to be working fine. very strange though
Scott
