Can't re-use search code
Thread began 11/12/2009 4:47 pm by David CHnet.com | Last modified 11/13/2009 12:59 pm by Eric Mittman | 2582 views | 4 replies |
David CHnet.com
I've serached and serached through the code but I can't find a reson for this ...
Search page, functioning
Loaded by index3.php as an include
There are 4 search fields (2 text, 2 dynamic drop downs)
Loads a results page
Results page
At the top of this results page the search fields are repeated in a "search toolbar" and preloaded with the serach values
Everything working perfectly
1. If I repeat the code in page inner16.php inside another page, alos calling inner70 ast the results page, it doesn't work.
2. Ditto if I copy inner16 to innerXX and try again.
3. Ditto if I load the working page, inner16, as an include into a different index2.php page which is exactly the same!
I feel like there is a relationship between inner16 and inner70 that I don't understand - the common denominator is the index3.php file that uses these as includes. I cannot find the problem anywhere ... !!!
I can post code, but not here ...
THANKS
David CHnet.com
Ticket please?
:confused: Can I have a support ticket for this please? It makes no sense ...
Were these pages generated by the wizard? Have you tried creating the pages with the wizard to see if you can add to the pages this way?
I have opened a ticket for you on this issue so we can exchange files. Please login and visit your support history to update the ticket.
David CHnet.com
Thanks Eric.
The pages were originally created using the wizard, but then things got a lot more complicated :-)
I have tried using the wizard to add to the pages and I think the code has been modified too much for the Wizard to recognise any more.
I'll send the files, thanks.
David
Thanks for the update, I will be checking into the ticket shortly.
