PowerStore - eCart not talking to Authorize.net
I have PS and everything is setup correct for Authorize.net (I believe).
I have the API and trans key infor in the globals file. I double checked and even regenereated another transaction key from Authorize.net.
When I process an order from the store the order is declined (I get the checkout-failure screen)
I logged into Authorized.net and do not see a declined transaction.
I then use Auth's virtual terminal to manually enter a transaction to make sure the card is good. Card is good and the transaction takes from the virtual terminal.
What could I be missing or have not setup properly? I've tried the order process on different cards and get the same results. Doesn't go through on PS shopping cart, but can enter the transaction in manually via the virtual terminal in auth.net.
Any thoughts?
Terry
