are there any Sliding Panel Widget advanced commands?
I am working on a sliding panel widget and know all the basics triggers, such as next frame, last frame, previous frame, etc. however the webpage I am working on is going to allow for users to upload their images onto a pre-structured sliding panel widget, the image will then be placed on a specific frame based on the filename, for example when the upload "image 1" it will be placed on frame one, image two "frame 2" etc., the problem I would like to avoid is if there is no image that has been uploaded to a requested frame via the trigger is there a way for it to automatically be skipped and instead go to the next frame which contains an image?
Here are the basics which I am using.... sliding_panels.html
