CSS MenuWriter 2.0 breaks PowerStore 2.0 Menus
Thread began 11/11/2009 7:03 pm by elton | Last modified 11/12/2009 2:14 pm by Eric Mittman | 763 views | 1 replies |
elton
Can this be fixed/enhanced to solve the problem
When attempting to use CSSMenuWriter 2.03 to update PowerStore 2.01 menu (just changing one content url) it breaks the Products (catagory) links to all Product menu subitems. The problem is that when it re-writes the menu, it leaves out the $Search parameters
<li><a href="<?php echo($assumedRoot); ?>Products_Results.php?Search=true&CategoryID=<?php echo $row_menuwriter_productcategories["CategoryID"]; ?>"><?php echo $row_menuwriter_productcategories["CategoryName"]; ?></a></li>
becomes
($assumedRoot); ?>Products_Results.php"><?php echo $row_menuwriter_productcategories["CategoryName"]; ?></a></li>
It also changes other sections of menu.php removing the
$WA_localRoot = "" .$WAGLOBAL_localRoot ."";
$WA_remoteRoot = "" .$WAGLOBAL_remoteRoot. "";
and replacing with
$WA_localRoot = "/";
$WA_remoteRoot = "/";
The PHP change for split/explode does not seem to be a problem
$WA_ddsArray = split("/", $WA_thisFile);
to
$WA_ddsArray = explode("/", $WA_thisFile);
I noticed that in treexml.xml,
that it changed one item as well:
mmtreecolumn name width from was expanded from 135 to 232.
I did a test of this with the latest PowerStore v2 files and what I experienced was that when I altered the menu the parameters for the specific category links remained in tact, here is what it looks like for me in the code after I finish:
I did notice however that the local and remote roots went to their default values, this part I had to update manually after the fact. I also noticed that the split function remained intact for me.
Please describe the exact steps you took when making the edits and I will do some more checking to try and determine what is going on.
elton
Response leaves no guidance as to what to do to debug
This post has been deleted.
