can I css this from my extension?
1407-03.aspx
I LOVE this menu. Is it possible to mimic some of the layout/features with dynamic drop downs or Menu Writer? I LOVE the dis-jointed rollover, but could eliminate that portion.
Thanks,
Lisa Segal
1407-03.aspx
Thanks,
Lisa Segal
Yes. that is Something Menu Writer could create as long as you have your images set up correctly. the only limitation would be that the second level is always going to have the same width when you hover over the first level.
The first level looks straight forward and you could just use background color. For the second level you will need to use a background image and make sure to specify the height.
Let me know if you have any other questions.
