Ability to edit Spry Accordion Content
Thread began 11/11/2009 3:34 am by fraskos393357 | Last modified 11/11/2009 10:36 am by Dani Chankhour | 2673 views | 5 replies |
fraskos393357
Hello
I am alsmost ready to purchase the power CMS. It looks simple and confident.
I have a question: In my layouts i very often use the spry accordion widget. Is it possible to edit the Accordion Panel Contents via the CMS? I suppose i must insert the snippet code there, right? Does it also work with edditing Spry Tabs?
At last but not least, is there a posibility to translate the text of the admin side in Greek in order to make the CMS easy to use for a Greek Client?
clickhappy392103
Later this afternoon I will give that a try on my practice site and will let you know if that works. I have no answer on the language question though, better wait for WA on that one.
clickhappy392103
accordian works
I had a few minutes, so I popped it in a spry accordian. It worked just fine, I only added text though.
fraskos393357
good. Do you suggest buying this CMS? Is it worth?
clickhappy392103
I really like it. I am new to php & mysql so I was a little frustrated at first. Luckily a member ( Neilo ) really helped me out by making a walkthru to get started. Look for the post about being "stuck on a 404" page. His explanation made it soooo much easier to follow. But I really like it now that I understand it better.
Dani Chankhour
In regard to the language question, i think it is possible to change it, but there might be a few issues in regard to PHP and the Database.
I would say make the language change and post any problem (if any) and we should be able to help you.
