CSS Menus within an I-Frame
Thread began 11/10/2009 7:26 pm by paul329747 | Last modified 11/11/2009 2:38 pm by Jimmy Wu | 683 views | 1 replies |
paul329747
Anyone know of a way to get a CSS menu (created with Web Assist CCS Menu Tool, of course) work within an I-Frame?
It doesn't open over the content below the I-Frame, it only shows inside the I-Frame. The height of the I-Frame is only high enough to show the first level menu, and it is not practical to increase the height of the I-Frame - too many many items within the menu.
Menu works great on its own, but in this instance, is HAS to be IFramed within a page on another site/another web server:
Example of Menu on its own:
test.asp
Example of Menu where it really needs to be:
aimloan
Any feedback is appreciated, even if it's "No way - it can't be done!"
Jimmy Wu
It looks like you're using a table based layout. If you switched to using a div based layout and using CSS to style the site, you would be able to set the z-index for the menu to show up on top of the other divs. Using the table based layout, I don't think there is a way to style the menu the way you want.
