eCart stuck on confirm page
Thread began 11/10/2009 12:04 pm by andre363997 | Last modified 11/11/2009 12:05 pm by Dani Chankhour | 1386 views | 3 replies |
andre363997
OK, everything works except, the checkout_success.php page doesn't show up. It stay on the confirm.php page. The transaction go through and the customer receives an email confirmation but after the submit button is clicked is redisplays the confirm.php page again. If you hit submit again you get a check out error that its a duplicate order.
confirm.php
Dani Chankhour
This indicates that your redirect is not working correctly. Did you run through the check out wizard to create your confirm page?
andre363997
Thanks for the quick reply.
Yes I did use the wizard to create the confirm page.
Here's the relevant code: (I think)
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) {
$AuthNet_required = array();
$AuthNet_required[0] = array();
$AuthNet_required[1] = array();
$AuthNet_itemized = array();
$AuthNet_itemized[0] = array();
$AuthNet_itemized[1] = array();
$AuthNet_optional = array();
$AuthNet_optional[0] = array();
$AuthNet_optional[1] = array();
$cartIndex = 0;
$nextIndex = 0;
$nextIndex = count($AuthNet_required[0]);
$AuthNet_required[0][$nextIndex] = "x_login";
$AuthNet_required[1][$nextIndex] = "Atomictesting";
$AuthNet_required[0][$nextIndex] = "x_tran_key";
$AuthNet_required[1][$nextIndex] = "Blastradius09";
$AuthNet_required[0][$nextIndex] = "x_version";
$AuthNet_required[1][$nextIndex] = "3.1";
$AuthNet_required[0][$nextIndex] = "x_invoice_num";
$AuthNet_required[1][$nextIndex] = "".session_id() ."";
$AuthNet_required[0][$nextIndex] = "x_test_request";
$AuthNet_required[1][$nextIndex] = "FALSE";
$AuthNet_required[0][$nextIndex] = "x_method";
$AuthNet_required[1][$nextIndex] = "CC";
$AuthNet_required[0][$nextIndex] = "x_type";
$AuthNet_required[1][$nextIndex] = "AUTH_CAPTURE";
$AuthNet_required[0][$nextIndex] = "x_relay_response";
$AuthNet_required[0][$nextIndex] = "x_delim_data";
$AuthNet_required[1][$nextIndex] = "TRUE";
$AuthNet_required[0][$nextIndex] = "x_delim_char";
$AuthNet_required[1][$nextIndex] = "::";
$AuthNet_required[0][$nextIndex] = "x_customer_ip";
$AuthNet_required[1][$nextIndex] = "".$_SERVER["REMOTE_ADDR"] ."";
$AuthNet_itemized[0][0] = "x_amount";
$AuthNet_itemized[1][0] = "".$atomicart->GrandTotal() ."";
$AuthNet_itemized[0][1] = "x_description";
$AuthNet_itemized[1][1] = "".$atomicart->TotalColumn("FullDetails") ."";
while ( !$atomicart->EOF() ) {
$nextIndex = count($AuthNet_itemized[0]);
$AuthNet_itemized[0][$nextIndex] = "ID";
$AuthNet_itemized[1][$nextIndex] = "".$atomicart->DisplayInfo("ID") ."";
$AuthNet_itemized[0][$nextIndex] = "Name";
$AuthNet_itemized[1][$nextIndex] = "".$atomicart->DisplayInfo("Name") ."";
$AuthNet_itemized[0][$nextIndex] = "Description";
$AuthNet_itemized[1][$nextIndex] = "".$atomicart->DisplayInfo("Description") ."";
$AuthNet_itemized[0][$nextIndex] = "Quantity";
$AuthNet_itemized[1][$nextIndex] = "".$atomicart->DisplayInfo("Quantity") ."";
$AuthNet_itemized[0][$nextIndex] = "Price";
$AuthNet_itemized[1][$nextIndex] = "".$atomicart->DisplayInfo("Price") ."";
$AuthNet_itemized[0][$nextIndex] = "Taxable";
$AuthNet_itemized[1][$nextIndex] = "YES";
$atomicart->MoveNext();
$cartIndex ++;
$atomicart->MoveFirst();
$nextIndex = count($AuthNet_optional[0]);
$AuthNet_optional[0][$nextIndex] = "x_card_num";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["cc_number"]))?$_POST["cc_number"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_exp_date";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["exp_month"]))?$_POST["exp_month"]:"") ."".((isset($_POST["exp_year"]))?$_POST["exp_year"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_card_code";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["cvv"]))?$_POST["cvv"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_email_customer";
$AuthNet_optional[1][$nextIndex] = "TRUE";
$AuthNet_optional[0][$nextIndex] = "x_tax_exempt";
$AuthNet_optional[1][$nextIndex] = "FALSE";
$AuthNet_optional[0][$nextIndex] = "x_first_name";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["firstname"]))?$_POST["firstname"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_last_name";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["lastname"]))?$_POST["lastname"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_address";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["street1"]))?$_POST["street1"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_city";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["city"]))?$_POST["city"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_state";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["state_province"]))?$_POST["state_province"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_zip";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["postcode"]))?$_POST["postcode"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_phone";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["phone"]))?$_POST["phone"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_fax";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["fax"]))?$_POST["fax"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_email";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["email"]))?$_POST["email"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_country";
$AuthNet_optional[1][$nextIndex] = "".((isset($_POST["country"]))?$_POST["country"]:"") ."";
$AuthNet_optional[0][$nextIndex] = "x_recurring_billing";
$AuthNet_optional[1][$nextIndex] = "NO";
$WAGatewayResponse = AuthNet_Post($AuthNet_required,$AuthNet_itemized,$AuthNet_optional);
if ($WAGatewayResponse) {
$atomicart->redirStr = "checkout_success.php";
else if ("checkout_failure.php" != "") {
header("Location: ". "checkout_failure.php");
exit();
Dani Chankhour
I have opened a support ticket to further assist you, please respond to the ticket at:
