DOCTYPE issue
Thread began 11/10/2009 11:59 am by bjgarner241692 | Last modified 11/12/2009 1:07 pm by bjgarner241692 | 1136 views | 3 replies |
bjgarner241692
DOCTYPE issue
I have a site using CSS MenuWriter. Most of the pages are very straightforward and everything works perfectly.
On the main page however, there is a search form utilizing Javascript that is messing me up.
If I include this line:
The search form will not work, but if I don't include that line, the CSS Menu does not work.
Obviously, this is not a problem with CSS MenuWriter but I'm wondering if anyone has come across something similar or if there is a different doctype that I can specify that may solve my issue.
15 years I've never concerned myself with this line. It's never even seemed to matter whether it was there or not.
try using a looser doctype, like 4.01 transitional:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
neilo
What happens when you try a different page encoding?
Modify > Page Properties > Title/Encoding
The menu writer should work on any of those, - I guess you just need to try different encodings until the search function works OK.
Non techie answer, but that would be my first step.
Edit: Sorry - Ignore mine - Jason beat me to it.
bjgarner241692
Thanks. I found a workaround with an iframe but I will play around with this.
I never knew that was there and slogging through samples I found online didn't seem very appealing!
