Powerstore accesories
Ive bought powerstore, and want to be able to fully customise each future website.
What webassist extensions do I need to also get to help me do this please?
Supersuite?
Supersuite?
The Super Suite is our total collection of tools, many of these tools can be used with Power Store to add additional functionality for example, if you need to amend the cart that is used for PowerStore you would make use of eCart to make these changes. Did you have some specific examples in mind of the type of edits you would like to be making to the Power Store? If you are just looking to update the design you can do most of that by making edits to the template file.
Thanks,
So u reckon I can edit the css on me own in dreamweaver, and then buy ecart to make amedments for a uk delivery?
Yes, you can definitely update the css manually if you would like. In the css folder is a file called mystyles.css, if you add css to this file it should not get overwritten if you alter the css using any of the WebAssist tools.
If you are interested in updating the checkout to a UK supported one then you would need to make use of eCart. You would also make use of eCart if you wanted to adjust the shipping quote server behaviors that are applied to the confirm page.
