Upload not available
I am using Digital File Pro and my Upload, Download, Rename and Delete are grayed out. Any ideas I have looked at all the FAQ and nothing has helped.
Do you have a page open that has a server language defined for it? This is the most likely cause for the menu items being grayed out. Also, you will need to add a form with a file field in it to be able to apply the file upload option.
Yes, I am using ASP. I created the page with a form and a file field then saved and still grayed out. I tryed this on one of my site pages with a template allied to it and then on a page without a template. justincase the problem was being caused by my template.
If you are using Digital File Pro v2, only PHP is supported, so you will not be able to work with ASP files. You can check the system requirements on any of our extensions by going to www.webassist.com, clicking on extensions and finding the extension you are interested in and clicking on it. There should be a link to system requirements under quick links on the right of the page.
