products not showing up on products page
The products show up in the boxes on the left, but nothing shows up in the product list. I managed to work through the other issues tonight, but am stuck again. Probably a related issue is in my admin area, the products DO show up listed there (though none of the pictures do) but when I click on update for any product I get the following error code:
Warning: require_once(/CSSMenuWriter/cssmw_admin/menu.php) [function.require-once]: failed to open stream: No such file or directory in /home/overhead/public_html/store/Admin/Products_Update.php on line 558
Fatal error: require_once() [function.require]: Failed opening required '/CSSMenuWriter/cssmw_admin/menu.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/overhead/public_html/store/Admin/Products_Update.php on line 558
this SEEMS like almost the same exact errors I was getting on the store pages when they wouldn't work, but when I go into cssmw_admin/menu.php it is a completely different set of code that doesn't correspond quite the same way the cssmw_home/menu.php code did. I was able to go see what the page was seeing and then go into the menu.php was saying, and got them to talk to each other. This time it is all greek to me. Nothing in Products_Update.php seems to correspond with what is in cssmw_admin/menu.php.
I can't find any lines in the cssmw_admin/menu.php code that are "require_once".
Additionally, some of the database seems fine, some of the other buttons work, but many buttons like Users, Categories, and others go to 404 not found.
