LOST in WADA.. Can You tell Me the whole workflow in relational Table ??
I made three table which are POL , ITEM , POLITEM in database.
according to "HELP" of managing relational table , the POL is MainTable and ITEM is options table and POLITEM is the relational table....
and POL to ITEM is Many to Many,
The ITEM table is already OK , and will never need to insert,update,delete again , because all item are already set in phpmyadmin...
So I use DA to make the pages for POL with all function to managing POL table ...
but ONly table POL means nothing to me , I need the data from POLITEM ,So in POL_Insert.php I make a table which is for selecting data from ITEM table with repeat selection server behavior in that page, So I can select the primary "keys" of the ITEM table out,After that , I use the managing relational table , then , save and try..... what I got is nothing in POLITEM table , but the POL got its ..... So, Obviously, I really don't know how to use the managing relational table server behavior , ....
So , is there any one help me to solve this??
What I want is A. insert multiple records in POLITEM ....
B.Update multiple records in POLITEM ....
C. delete multiple records in POLITEM ....
D. what exactly the managing relational table server behavior do ?? <-- can you explain more clearly by using a example??
