another search
Thread began 11/03/2009 4:44 pm by brobert123392308 | Last modified 11/03/2009 4:53 pm by Jason Byrnes | 688 views | 1 replies |
brobert123392308
another search
How about this one, simple search with the search wizard?
I must be doing something wrong.
any help?
<?php require_once('Connections/connNids.php'); ?>
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: emailtest;
//Searchpage: emailtest.php;
//Form: form1;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparisonFromEdit("received","From","AND",">=",2);
$WADbSearch1->addComparison("received","".WAQB_getEndDate($_POST["To"]) ."","AND","<=",2);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_emailtest"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_emailtest"]) && $_SESSION["WADbSearch1_emailtest"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_emailtest"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_connNids, $connNids);
$query_emailtest = "SELECT message FROM message";
setQueryBuilderSource($query_emailtest,$WADbSearch1,false);
$emailtest = mysql_query($query_emailtest, $connNids) or die(mysql_error());
$row_emailtest = mysql_fetch_assoc($emailtest);
$totalRows_emailtest = mysql_num_rows($emailtest);
<head>
<link href="mystyles.css" rel="stylesheet" type="text/css" />
</head>
<body>
<form id="form1" name="form1" method="post" action="emailtest.php">
<label>From:
<input type="text" name="From" id="From" />
</label>
<label>Submit
<input type="submit" name="Submit" id="Submit" value="Submit" />
</label>
<label>To:
<input type="text" name="To" id="To" />
</label>
<table cellpadding="2" cellspacing="0" border="0">
<tr>
<td align="center"><input type="hidden" name="WADbSearch1" value="Submit" /></td>
</tr>
</table>
</form>
</body>
</html>
mysql_free_result($emailtest);
You have also submitted this issue in another thread for which I opens a support ticket.
Please reply to your support ticket by logging into your support history:
