Built site assist site into wrong site
Thread began 11/03/2009 1:52 pm by takingchances6176651 | Last modified 11/04/2009 2:38 pm by Eric Mittman | 977 views | 1 replies |
I accidentally had the wrong site open when I went to "build site" and SiteAssist imported all the pages into that site. Two questions:
1. How can I retrieve the site I built in site assist to import it into the right site?
2. Is there an easy way to delete the pages from the site it imported the pages into or do I have to do it manually?
You SiteAssist site should be saved as a preset and still available from within the wizard so that you can apply it to any other DW site you have.
To remove the bad site you must manually delete all of the SiteAssist generated files, sorry. There is no automatic method for removing an existing site.
