Horizontal Vertical Looper
Thread began 11/02/2009 6:27 pm by abramhoman316506 | Last modified 11/03/2009 9:41 am by abramhoman316506 | 1253 views | 2 replies |
abramhoman316506
I brought eCart a little while ago and trying to configure .asp dynamic data to display 3 across and then down however having a tough time finding code to do it. The site I am testing on now is gear3Rows.asp. I can get it to fill down but not across and down like below
123
456
789
Can you help?
anonymous
Do you by chance have DataAssist?
You could use the DataAssist Dynamic Repeating Table to do exactly as you describe. You could also hand code div tags that are all floated left and have a width of one third of the space your displaying within and then just run a repeat region and they will fill out in rows of 3.
Regards,
Brian
abramhoman316506
Working But Navigation problems
Hi Brian,
I found a Vertical Looper Dreamweaver Extension yesterday that did the trick. HorizontalLooper/ however now I am having some troubles with the Navigation. Will data assist help with navigation for eCart as well? The app that comes with Dreamweaver won't drill down enough for it to work.
