sql issue.
Thread began 11/02/2009 2:21 pm by paul372337 | Last modified 11/13/2009 4:21 pm by Eric Mittman | 4717 views | 16 replies |
paul372337
sql issue.
When I run the prepackaged cms.sql file , I get the following error:
ERROR 1064 at line 2: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'CURRENT_TIMESTAMP,
PRIMARY KEY (`HistoryID`)
)' at line 7
Any help would be appreciated, thanks!
What is the version of MySQL that you are working with? If the code does not like the default value then the version could be an issue. Please post back with this info so we can look into this issue more.
paul372337
I cannot seem to get the version of SQL from my customer's host. :(
Is there an SQL query to retrieve that information?
paul372337
According to phpinfo(), my customer's host has a client api version of 4.0.27?
I have done some looking around and cannot determine why you are getting this error when attempting to load the sql file.
One potential work around would be to use the function call version of this default value, it would look like this in the sql:
`HistoryDate` timestamp NOT NULL default CURRENT_TIMESTAMP(),
If this gives you the same error you should just remove the default clause here, then after the table is created you can go back after the fact and update the columns default value to be the current_timestamp. Please give this a try and let me know how it works for you.
paul372337
Still gives this:
ERROR 1064 at line 2: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'CURRENT_TIMESTAMP(),
)' at line 7
You should just remove the default clause here, then after the table is created you can go back after the fact and update the columns default value to be the current_timestamp.
The part you need to remove is this:
paul372337
That did it!
Although without myphpadmin I'm not sure where/how to add the value to the column after the fact. Will the software work fine without this? It appears to be working at the present without it, but I also have not pushed it in depth.
It is a fairly important part for retaining the versions of the pages you are creating. Without this timestamp in this field you will have trouble checking the history of a page and reverting back to it. Does your GUI tool allow you to edit the table like this? If you are using phpmyadmin you should be able to alter the table by adding in the default value for this column. The version of MySQL that you are using may be part of the problem but I was not able to confirm this in my searching.
paul372337
My server does not have myphpadmin (that's what I was attempting to say earlier) or anything of the sort. It sends me to a page on the mysql website that no longer exists to get some form of admin tool and tells me what port I can connect on, but that's as far as it goes.
However, it appears to be pulling the timestamp anyway.
I'm currently facing a different problem, now, the php echo of the content seems to be breaking the site at the line where the php echo goes. [Edit: To clarify, the site is cropped beginning at the line with the php echo WA_getblahblahblah(args); command, losing the rest of the site. It's as if the WA_getblah(args) method is failing and php times out waiting on it to fail.]
index.php
I set this up on another customer site (one that I host) and it appears to be working just fine, so I'm fairly stumped.
