Still getting the error messages
Thread began 10/25/2009 11:04 pm by esther379760 | Last modified 10/26/2009 7:47 pm by Eric Mittman | 735 views | 1 replies |
esther379760
I'm getting the same errors as mikeybabe did in the previous message. I went thru all the fixes in that URL, then went to Adobe's site and went thru a couple more. Still getting the exact same error messages.
The only thing I have NOT yet tried is uninstalling DW and reinstalling. Before i did all that, I wanted to know if there is anything else I can do.
Already have done:
Uninstalled all my WA extensions
Reinstalled only Menu Writer. (3 times)
Deleted the Config folder and recreated
Deleted the Sites folder and recreated
Deleted the Prefs folder and recreated. (big mistake ;-)
Thanks...
esther
It sounds like you have gone through all the motions, when you deleted or renamed your configuration folder did you then uninstall the remaining extensions that were listed in the extension manager? If you did not uninstall all of the listed extensions after deleting or renaming the config folder then you can recreate the same problem. If you have done this and are still having a problem please post back with the exact error message you are getting.
