Cannot get this to work
Thread began 10/22/2009 10:19 am by John Langer | Last modified 10/22/2009 2:15 pm by Jason Byrnes | 2295 views | 5 replies |
John LangerBeta Tester
I've done this before and it worked fine but now...
I have two tables with corresponding recordsets
The Parent is countries (Only two The US and the UK)
The Child is regions (States for the US and counties for the UK
I get the Countries to display OK but the regions remain blank.
This is the code for the page. Could someone cast their eye over it and tell me where I'm going wrong please?
<?php error_reporting(E_ALL);
ini_set('display_errors''1');?>
require_once('Connections/localhost.php'); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
  if (
PHP_VERSION 6) {
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
mysql_select_db($database_localhost$localhost);
$query_rsCountry "SELECT * FROM country";
$rsCountry mysql_query($query_rsCountry$localhost) or die(mysql_error());
$row_rsCountry mysql_fetch_assoc($rsCountry);
$totalRows_rsCountry mysql_num_rows($rsCountry);
$query_rsRegion "SELECT * FROM regions";
$rsRegion mysql_query($query_rsRegion$localhost) or die(mysql_error());
$row_rsRegion mysql_fetch_assoc($rsRegion);
$totalRows_rsRegion mysql_num_rows($rsRegion);
if ($row_rsRegion)     {
  echo
"<SC" "RIPT>\n";
  echo
"var WAJA = new Array();\n";
$oldmainid 0;
$newmainid $row_rsRegion["FKcountryID"];
  if (
$oldmainid == $newmainid)    {
$oldmainid "";
$n 0;
  while (
$row_rsRegion)     {
    if (
$oldmainid != $newmainid)     {
      echo
"WAJA[".$n."] = new Array();\n";
      echo
"WAJA[".$n."][0] = '".WA_DD_Replace($newmainid)."';\n";
$m 1;
    echo
"WAJA[".$n."][".$m."] = new Array();\n";
    echo
"WAJA[".$n."][".$m."][0] = "."'".WA_DD_Replace($row_rsRegion["regionID"])."'".";\n";
    echo
"WAJA[".$n."][".$m."][1] = "."'".WA_DD_Replace($row_rsRegion["regionName"])."'".";\n";
$m++;
    if (
$oldmainid == 0)      {
$oldmainid $newmainid;
    if (
$row_rsRegion)     {
    if (
$n++;
  echo
"var rsRegion_WAJA = WAJA;\n";
  echo
"WAJA = null;\n";
  echo
"</SC" "RIPT>\n";
function
WA_DD_Replace($startStr)  {
$startStr str_replace("'""|WA|"$startStr);
$startStr str_replace("\\""\\\\"$startStr);
$startStr preg_replace("/[\r\n]{1,}/"" "$startStr);
  return
$startStr;
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<script type="text/javascript">
function WA_ClientSideReplace(theval,findvar,repvar)     {
  var retval = "";
  while (theval.indexOf(findvar) >= 0)    {
    retval += theval.substring(0,theval.indexOf(findvar));
    retval += repvar;
    theval = theval.substring(theval.indexOf(findvar) + String(findvar).length);
  retval += theval;
  if (retval == "" && theval.indexOf(findvar) < 0)    {
    retval = theval;
  return retval;
function MM_findObj(n, d) { //v4.01
  var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
  if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
  for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
  if(!x && d.getElementById) x=d.getElementById(n); return x;
function WA_UnloadList(thelist,leavevals,bottomnum)    {
  while (thelist.options.length > leavevals+bottomnum)     {
    if (thelist.options[leavevals])     {
      thelist.options[leavevals] = null;
  return leavevals;
function WA_FilterAndPopulateSubList(thearray,sourceselect,targetselect,leaveval,bottomleave,usesource,delimiter)     {
  if (bottomleave > 0)     {
    leaveArray = new Array(bottomleave);
    if (targetselect.options.length >= bottomleave)     {
      for (var m=0; m<bottomleave; m++)     {
        leavetext = targetselect.options[(targetselect.options.length - bottomleave + m)].text;
        leavevalue  = targetselect.options[(targetselect.options.length - bottomleave + m)].value;
        leaveArray[m] = new Array(leavevalue,leavetext);
    else     {
        leavetext = "";
        leavevalue  = "";
  startid = WA_UnloadList(targetselect,leaveval,0);
  mainids = new Array();
  if (usesource)    maintext = new Array();
  for (var j=0; j<sourceselect.options.length; j++)     {
    if (sourceselect.options[j].selected)     {
      mainids[mainids.length] = sourceselect.options[j].value;
      if (usesource)     maintext[maintext.length] = sourceselect.options[j].text + delimiter;
  for (var i=0; i<thearray.length; i++)     {
    goodid = false;
    for (var h=0; h<mainids.length; h++)     {
      if (thearray[i][0] == mainids[h])     {
        goodid = true;
        break;
    if (goodid)     {
      theBox = targetselect;
      theLength = parseInt(theBox.options.length);
      theServices = thearray[i].length + startid;
      var l=1;
      for (var k=startid; k<theServices; k++)     {
        if (l == thearray[i].length)     break;
        theBox.options[k] = new Option();
        theBox.options[k].value = thearray[i][l][0];
        if (usesource)     theBox.options[k].text = maintext[h] + WA_ClientSideReplace(thearray[i][l][1],"|WA|","'");
        else               theBox.options[k].text = WA_ClientSideReplace(thearray[i][l][1],"|WA|","'");
        l++;
      startid = k;
    for (var n=0; n<leaveArray.length; n++)     {
      targetselect.options[startid+n] = new Option();
      targetselect.options[startid+n].value = leaveArray[n][0];
      targetselect.options[startid+n].text  = leaveArray[n][1];
  for (var l=0; l < targetselect.options.length; l++)    {
    targetselect.options[l].selected = false;
  if (targetselect.options.length > 0)     {
    targetselect.options[0].selected = true;
</script>
</head>
<body>
<form  action="" method="post" name="form1" id="form1">
  <table>
    <tr>
      <th scope="row">country</th>
      <td><select name="country" id="country" onchange="WA_FilterAndPopulateSubList(rsRegion_WAJA,MM_findObj('country'),MM_findObj('regions'),1,0,false,': ')">
        <option value="">Please choose</option>
do {
        <option value="<?php echo $row_rsCountry['countryID']?>"><?php echo $row_rsCountry['countryName']?></option>
} while ($row_rsCountry mysql_fetch_assoc($rsCountry));
$rows mysql_num_rows($rsCountry);
  if(
$rows 0) {
mysql_data_seek($rsCountry0);
      </select></td>
    </tr>
    <tr>
      <th scope="row">region</th>
      <td><select name="regions" id="regions">
        <option value="">Choose country first</option>
do {
<option value="<?php echo $row_rsRegion['regionID']?>"><?php echo $row_rsRegion['regionName']?></option>
} while ($row_rsRegion mysql_fetch_assoc($rsRegion));
$rows mysql_num_rows($rsRegion);
  if(
$rows 0) {
mysql_data_seek($rsRegion0);
      </select></td>
    </tr>
    <tr>
      <th scope="row">&nbsp;</th>
      <td>&nbsp;</td>
    </tr>
  </table>
</form>
</body>
</html>
mysql_free_result
($rsCountry);
mysql_free_result($rsRegion);
This is the SQL
-- Table structure for table `country`
CREATE TABLE IF NOT EXISTS `country` (
`countryID` varchar(30) NOT NULL,
`countryName` varchar(30) NOT NULL,
PRIMARY KEY (`countryID`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1;
-- Table structure for table `regions`
CREATE TABLE IF NOT EXISTS `regions` (
`regionID` int(11) NOT NULL AUTO_INCREMENT,
`FKcountryID` int(2) NOT NULL DEFAULT '1',
`regionName` varchar(128) NOT NULL,
`regionAbbr` varchar(8) DEFAULT NULL,
PRIMARY KEY (`regionID`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 ;
Thanks in advance.
John,
I dont see a problem in the page code.
Do you have this hosted online where I could take a look?
Or perhaps you could export the data from the country and regions tables so i could recreate it on my end.
Hi Jason,
Many thanks for taking a look.
The page is here http://testing.wltmdating.com/region_picker.php
I've also attached the mysql dump
In the country table, the countryID column is being set to the name of the country.'
INSERT INTO `country` (`countryID`, `countryName`) VALUES
('United Kingdom', 'United Kingdom'),
('United States', 'United States');
In the region table, the FKcountryIDcolumn that should relate to the country.countryID is being set to a numeric value.
NSERT INTO `regions` (`regionID`, `FKcountryID`, `regionName`, `regionAbbr`) VALUES
(1, 1, 'Aberdeen City', NULL),
(2, 1, 'Aberdeenshire', NULL),
(3, 1, 'Angus', NULL),
etc.....
change the country.countryID column to be an integer and set it to 1 for United Kingdom and 2 for United States:
`countryID` int(11) NOT NULL,
-- Dumping data for table `country`
(1, 'United Kingdom'),
(2, 'United States');
It's always something simple isn't it! I feel such a fool :)
Many thanks Jason. Another pair of eyes makes all the difference.
No worries John.
