How To Ad Extra Session To User Authenticate
Thread began 10/22/2009 11:48 am by Cologne | Last modified 10/22/2009 7:25 pm by Jason Byrnes | 915 views | 1 replies |
Cologne
ho can I ad a session to the authenticate user dialog? I can set session that came from the database, ok. but i need a time set into a session, when the login succeed.
Finally, does anyone know how i can manage to count the failed logins?
Denis
Best way to set the time in a session on login success is to add a set set session value server behavior on the login success redirect.
Set the trigger to session does not exist. Set the value to <?php echo(date("m/d/Y")); ?>
to count the failed logins, you could create a table to hold the login count. On the failed login page, create a recordset to return the currant failed count.
Add an update record server behavior to the page and set the count column to use the recordset count + 1.
