Problems with a rewrite rule in cms
Thread began 10/21/2009 5:47 pm by dallySP | Last modified 10/23/2009 10:28 am by dallySP | 1422 views | 1 replies |
dallySP
Hi, I've created a cms using webassist extensions, and have set up a dummy site to demonstrate and test this - its a bit basic but does the job.
I'm having a problem creating SEF urls. I've created rewrite rules in my .htaccess file, but there seems to be a redirect happening somewhere that is making the query string appear in the address bar. You can check it out at the following url:
www.onespotcms.co.uk (some of the product links are a bit dodgy as I need to eliminate the spaces).
My rewrite rules are as follows:
RewriteRule ^company/([A-Za-z0-9-]+)\.php$ http://www.onespotcms.co.uk/company.php?PageName=$1 [NC,L]
RewriteRule ^product/([A-Za-z0-9-]+)\.php$ http://www.onespotcms.co.uk/product.php?CatName=$1 [NC,L]
Its been suggested that maybe the php is redirecting the headers somehow. I've had someone else check out my .htaccess file which doesn't contain any errors - can anyone shed any light on this?
dallySP
OK - figured it out - it was nothing to do with the php, but thought I'd put the solution down in case anyone else was having the same problem. The .htaccess rules weren't quite right. Once they were amended as follows they worked fine. I also had to put a slash in front of all my relative links in order for them to work:
RewriteRule ^company/([A-Za-z0-9-]+)\.php$ company.php?PageName=$1 [NC,L]
RewriteRule ^product/([A-Za-z0-9-]+)\.php$ product.php?CatName=$1 [NC,L]
