How do I restrict a comma from a number validation?
Thread began 10/21/2009 5:00 am by RichGags | Last modified 10/21/2009 2:41 pm by Jimmy Wu | 3801 views | 3 replies |
RichGags
Ive got the client Validation toolkit checking a field on my form before submitting it to my credit card processor. I am getting an error back from my processor "Invalid XML" only if the user enters a number in the thousands with a comma.
How would I either strip the comma out, or make the message pop up "Dont put a comma in your number"?
Thanks!
Rich
PS: Here's my code...
on the button...
WAValidateNM(document.form1.chargetotal,'- Invalid Amount',1,20000,2,'','',',.',document.form1.chargetotal,0,true);
function...
function WAValidateNM(formElement,errorMsg,minLength,maxLength,allowDecimals,roundDecimals,reformatDecimals,punctuationMarks,focusIt,stopIt,required) {
var isValid = true;
var theThousand = punctuationMarks.charAt(0);
var theDecimal = punctuationMarks.charAt(1);
var theCheck = 11/10;
var trueDecimal = (String(theCheck).charAt(1));
var value = formElement.value;
var decimalIndex = value.length;
if (punctuationMarks.indexOf(trueDecimal)<0 && value.indexOf(trueDecimal)>=0) {
isValid = false;
if (value.lastIndexOf(theDecimal)>=0) {
decimalIndex = value.lastIndexOf(theDecimal);
while (value.indexOf(theThousand)>=0) {
if ((decimalIndex-(value.lastIndexOf(theThousand)+1))%3 != 0)
isValid = false;
value = value.substring(0,value.lastIndexOf(theThousand)) + value.substring(value.lastIndexOf(theThousand)+1);
if (trueDecimal != theDecimal) {
while (value.indexOf(theDecimal)>=0) {
value = value.substring(0,value.indexOf(theDecimal)) + trueDecimal + value.substring(value.indexOf(theDecimal)+1);
if ((!document.WAFV_Stop && !formElement.WAFV_Stop) && !(!required && value=="")) {
for (var x=0; x<value.length; x++) {
if ((value.charAt(x)<0 || value.charAt(x) > 9) && (value.charAt(x) != " " && value.charAt(x) != "," && value.charAt(x) != ".")) {
isValid = false;
if (value == "") {
isValid = false;
var oldVal = String(value);
if (oldVal.indexOf(trueDecimal)>=0) {
while (oldVal.charAt(oldVal.length-1)=="0" || oldVal.charAt(oldVal.length-1) == trueDecimal) {
if (oldVal.charAt(oldVal.length-1) == trueDecimal) {
oldVal = oldVal.substring(0,oldVal.length-1);
break;
else oldVal = oldVal.substring(0,oldVal.length-1);
if (oldVal.indexOf(trueDecimal)==0)
oldVal = "0" + oldVal;
if (String(allowDecimals) !="" ) {
if (String(value).indexOf(".") > 0 && ((String(value).indexOf(".") + allowDecimals + 2 <= String(value).length) || allowDecimals == 0)) {
isValid = false;
value = parseFloat(value);
if (isNaN(value)) {
isValid = false;
else if (String(value).length!=String(oldVal).length && String(oldVal).substring(String(value).length+1).search(/^\.?0*$/) == -1 ) {
isValid = false;
else if ((String(minLength) != "" && minLength > value) || (String(maxLength) != "" && maxLength < value)) {
isValid = false;
if (!isValid) {
WAAddError(formElement,errorMsg,focusIt,stopIt);
else {
if (value != "") {
if (roundDecimals != "") {
value = Math.round(value*roundDecimals)/roundDecimals;
if (reformatDecimals != "") {
value = String(value);
if (value.indexOf(trueDecimal)<0)
value += trueDecimal;
if (value.indexOf(trueDecimal) < value.length - reformatDecimals) {
value = value.substring(0,value.indexOf(trueDecimal) + reformatDecimals + 1);
else {
while (value.indexOf(trueDecimal) > value.length - reformatDecimals - 1) {
value += "0";
while (value.indexOf(trueDecimal)>=0) {
value = value.substring(0,value.indexOf(trueDecimal)) + theDecimal + value.substring(value.indexOf(trueDecimal)+1);
if (roundDecimals != "" || reformatDecimals != "")
formElement.value = value;
Jimmy Wu
What you can do is to apply a Restrict Content validation with Validation Toolkit and put the comma in the Don't allow, select includes in the dropdown and leave the replace with blank. This will check if there are any commas are entered into the form field.
RichGags
Worked perfectly. Thanks.
Jimmy Wu
Great to hear. If you run into any additional issues, feel free to make a new thread.
