Product Image in the display manager the same for all products
Thread began 10/20/2009 11:35 am by xberniex250371773 | Last modified 10/20/2009 1:32 pm by Jason Byrnes | 721 views | 1 replies |
xberniex250371773
Product Image in the display manager the same for all products. When you click on add to cart button and get redirected to the cart page all items in the cart have the same image but all other info is correct. Why is this happening to me?
The image name for the product should be added to the cart using the add to cart button.
On the cart page, you should be getting the image name from the cart.
If it is showing the same image for each item in the cart, there 2 most likely causes:
1) In the Add to cart button, you have it set to look up the item ID from a recordset, the image column is bound to a differant recordset.
2) On the cart display page, you are retrieving the image name from a recordset rather than the cart.
