Error Generating menu
Thread began 10/20/2009 7:54 am by clive.henderson222953 | Last modified 10/27/2009 1:52 pm by Jimmy Wu | 1646 views | 3 replies |
I'm getting the following error when trying to create a vertical menu using dynamic data
Error generating menu(wagenerate writefile)
Type Error Node(inde] .html has no properties
I've tried deleting the wincache file as suggested in the threads but it does not resolve it.
I'm using CS3 under Vista and version 2.0.3 of menuwriter
Can anyione help please?
Clive
Jimmy Wu
Could you attach a screen shot of the error message?
Did you change any other settings other than making the menu vertical and using dynamic menu items?
Error on dynamic menu creation
Originally Said By: Jimmy Wu
Hi Jimmy, Thanks for the reply.
I've attached 3 jpegs as follows:
err1 - shows the wizard parameters
err2 - ahows response before I submit OK
err3 - Shows error response after processing
Hope this throws a light on the problem
Clive
Jimmy Wu
I have opened up a backend ticket for you. You can check this ticket by signing in to your account on www.webassist.com and checking your support history.
