I have fiddled around with adding that code and it still does not seem to work.
Here is the example i am messing with (only has blind, no fade)
</style>
<script src="SpryAssets/SpryEffects.js" type="text/javascript"></script>
function MM_effectBlind(targetElement, duration, from, to, toggle)
Spry.Effect.DoBlind(targetElement, {duration: duration, from: from, to: to, toggle: toggle});
function MM_goToURL() { //v3.0
var i, args=MM_goToURL.arguments; document.MM_returnValue = false;
for (i=0; i<(args.length-1); i+=2) eval(args[i]+".location='"+args[i+1]+"'");
</script>
</head>
<body class="oneColFixCtr">
<div id="container">
<div id="mainContent" onclick="MM_effectBlind(this, 1000, '100%', '0%', false);MM_goToURL('plugins/parent','index.html');return document.MM_returnValue">
<h1> level heading </h1>
<p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam, justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo porttitor, felis. Nam blandit quam ut lacus. Quisque ornare risus quis ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at, odio.</p>
<!-- end #mainContent --></div>
<!-- end #container --></div>
</body>
</html>
where do I add it?
thanks!
