JavaScript Error
When I try to apply the QueryString Binding SB, I get a Javascript error as per the attached image.
I have tried deleting the WinFileCache file while Dreamweaver is closed but it still happens.
Do you have eCart installed? If so, make sure it is version 4.5.2, this is the latest version available from the download center. if you have a previous version installed, you will need to uninstall it from the extension manager before installing the newer version.
it would be good to check other WebAssist extensions you may have installed as well against the versions available in the download center to ensure that you are using the latest releases.
Yes I have all the latest versions of WebAssist extensions. I alway's update them as soon as new versions are made available.
I have noticed that even though I get the JavaScript error, it seems to create the correct code, I continued with adding the Sort SB and it worked fine. I would still like to know what is cause ing the Javascript error though.
I have created a support ticket so we can look into this issue. To view and edit your support ticket, please log into your support history:
I also get the same error. The sorting feature works, but I still get the JavaScript error stated in this thread. I have deleted my chache as recommended in another thread, but I still get it.
login.php
