Missing file directory
Thread began 10/13/2009 11:32 am by eaddudley390229 | Last modified 10/14/2009 1:32 pm by Jimmy Wu | 1222 views | 3 replies |
eaddudley390229
Hello.
I've just installed eCart as a extension for dreamweaver but when i try to use the eCart it saids it missing a directory.
I've already rename the connection folder, reinstalled the extension, and deleted the MacFileCache-EEEE2300 file. Please help so that I may began to build my website.
Jimmy Wu
What directory is it listing as missing? Could you post a screen shot of the error message?
eaddudley390229
Written below is the exact error along with an image.
While executing onLoad in WA eCart Ser.htm, the following JavaScript error(s) occurred:
At line 214 of file "mydiskImage:Applications:Adobe Dreameaver CS4: Configuration:Shared:WebAssist:eCart:Library:Shared_Ser_Mactivation.js": document.formLayer.document has no properties
Jimmy Wu
That line of code should not be reached unless you are unable to connect with our activation server.
Do you have a firewall, security software or virus scan that may interfere with the extension connecting to our activation server?
