Driving Directions Not Showing With Destination Address as Coordinates
I am using lat/long to show the destination and using the visitor's city,province/state and country from their IP to be the default 'from' address. If I pass a street address as the destination, it gives driving directions but when I provide lat/long, the point on the map is exact but the driving directions don't render...
Is there any way to show driving directions to a lat/long when the origin is a city/state/country (with the option for a user to input their street address)?
** NOTE: WHEN VAR ADDRESS_0 IS POPULATED THE DIRECTIONS WORK FINE BUT THE PIN IS NOT EXACT... WHICH IS WHY I USE LAT/LONG FOR MY RURAL ADDRESSES... IF I BLANK OUT THESE VALUES, THE MAPPING IS PERFECT BUT NO DRIVING DIRECTIONS APPEAR
Below is my section of code that I think is pertinent:
function wagmp_map_3() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_3')) return false;
var map = new GMap2(document.getElementById('wagmp_map_3'));
wagmp_map_3_obj = new WAMapRef(map);
map.enableContinuousZoom();
map.enableDoubleClickZoom();
map.addControl(new GLargeMapControl());
map.addControl(new GMapTypeControl());
var geocoder = new GClientGeocoder();
var fromAddress = {
enabled: true,
street: '<?php echo str_replace("'", "\'", "".$_SESSION['mystreet'] .""); ?>',
city: '<?php echo str_replace("'", "\'", "".$_SESSION['mycity'] .""); ?>',
state: '<?php echo str_replace("'", "\'", "".$_SESSION['myprovince'] .""); ?>',
zip: '',
country: '<?php echo str_replace("'", "\'", "".$_SESSION["country"] .""); ?>',
full: '<?php echo $_SESSION['mystreet'].",".$_SESSION['mycity'].",".$_SESSION['myprovince'].",".$_SESSION["country"]; ?>'
var icon_0 = new GIcon();
icon_0.image = 'google_javascript/images/traditionalflat_pacifica.png';
icon_0.shadow = 'google_javascript/images/traditionalflat_shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,33);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'google_javascript/images/traditionalflat_pacifica.gif';
icon_0.mozPrintImage = 'google_javascript/images/traditionalflat_pacifica_mozprint.png';
icon_0.printShadow = 'google_javascript/images/traditionalflat_shadow.gif';
icon_0.transparent = 'google_javascript/images/traditionalflat_pacifica_transparent.png';
var address_0 = {
street: '',
city: '',
state: '',
zip: '',
country: '',
infowindow: 'custom',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><?php echo str_replace("'", "\'", "<strong>Address:</strong><br />".$row_dealermap['street_address'] ."<br />".$row_dealermap['city'] .", ".$row_dealermap['province'] ." ".$row_dealermap['country'] .""); ?></span>',
full: '<?php echo str_replace("'", "\'", "".$row_dealermap['street_address'] .""); ?>, <?php echo str_replace("'", "\'", "".$row_dealermap['city'] .""); ?>, <?php echo str_replace("'", "\'", "".$row_dealermap['province'] .""); ?>, <?php echo str_replace("'", "\'", "".$row_dealermap['country'] .""); ?>',
isdefault: true,
addressType: 'coordinates',
loop: '',
latitude: '<?php echo $row_dealermap['latitude']; ?>',
longitude: '<?php echo $row_dealermap['longitude']; ?>',
markerStyle: 'Google Traditional (flat)',
markerColor: 'Pacifica'
if (address_0.addressType == "coordinates") {
var cacheReturn = '';
} else {
var cacheReturn = searchCache(address_0.full, address_0.zip);
if (cacheReturn != "" || (address_0.addressType == "coordinates")) {
if(address_0.addressType == "coordinates") {
var latitude = address_0.latitude;
var longitude = address_0.longitude;
} else {
var latitude = cacheReturn.substring(1,cacheReturn.indexOf(",")-1);
var longitude = cacheReturn.substring(cacheReturn.indexOf(",")+1,(cacheReturn.length)-1);
var point = new GLatLng(latitude, longitude);
if (point && !isNaN(latitude)) {
wagmp_map_3_obj.addressFailed = false;
var marker_0 = new GMarker(point, icon_0);
GEvent.addListener(marker_0, 'click', function() {
marker_0.openInfoWindowHtml(address_0.infowindowtext);
if(!fromAddress.enabled || 'address_0' != 'address_0') {
map.setCenter(point, 13);
map.addOverlay(marker_0);
wagmp_map_3_obj.markers.push(marker_0);
wagmp_map_3_obj.addresses.push(address_0);
wagmp_map_3_obj.icons.push(icon_0);
wagmp_map_3_obj.points.push(point);
} else {
if (wagmp_map_3_obj.addressFailed) {
map.setCenter(new GLatLng(30, -98), 3);
wagmp_map_3_obj.addressFailed = true;
} else if (address_0.addressType == "address") {
geocoder.getLatLng (
address_0.full,
function(point) {
if(point) {
this.addressFailed = false;
addToCache(address_0.full, '', point);
} else {
var noZipAddress = address_0.full.replace((address_0.zip+','), '');
geocoder.getLatLng (noZipAddress,
function(point) {
if(point) {
addToCache(address_0.full, address_0.zip, point);
if (!fromAddress.enabled || 'address_0' != 'address_0') {
} else {
directions = new GDirections(map, document.getElementById('wagmp_directions_3'));
GEvent.addListener(directions, "error", function() {
map.setCenter(wagmp_map_3_obj.points[0], 13);
map.addOverlay(wagmp_map_3_obj.markers[0]);
directions.load('from: ' + fromAddress.full + ' to: ' + address_0.full);
wagmp_map_3_obj.directions = directions;
