Admin error
Thread began 10/12/2009 6:26 am by i.edwards384429 | Last modified 10/12/2009 12:36 pm by Dani Chankhour | 1257 views | 1 replies |
i.edwards384429
Admin error
Hi
this is the start of a new learning curve so I took advise and purchased this pack as a good stepping stone to mstart developing from.
Ok I wnet through the instructions and had no problem until I reached the section
" setting up the admin section......"
Logged on put in my setup username and password and index.php appeared.
Then tried the search button (althoughI have no users yet) and got what I suspect is the mysql/php blue screen of death
Warning: require_once(../Connections/localhost.php) [function.require-once]: failed to open stream: No such file or directory in C:\wamp\www\1stmodelagency\Admin\users_Results.php on line 2
Fatal error: require_once() [function.require]: Failed opening required '../Connections/localhost.php' (include_path='.;C:\php5\pear') in C:\wamp\www\1stmodelagency\Admin\users_Results.php on line 2
Ok I'm ok on html and using DW but this is a new ball game
would appreciate any help
thanks
Ian
Dani Chankhour
The error indicates that the reference to the connection file is not correct.
Please make sure that you have a Connections folder on the save level as your Admin folder, and ensure you have a localhost.php file in your Connections folder.
