While executing onClick... error occurred.
Thread began 10/11/2009 12:39 am by jeremydavies390881 | Last modified 10/15/2009 10:00 pm by Eric Mittman | 4306 views | 14 replies |
jeremydavies390881
Alright, I think I've figured out the whole MySQL/PHP database thing.
But when I go to click Submit on the form, this comes up:
405 Method Not allowed
Method Not Allowed
The requested method GET is not allowed for the URL /photoform.html.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
______________________________________________
So, I go into the Form settings and the Select form method is at POST. I tried switching to GET, and this error comes up:
While executing onClick in WAFB_AddForm.htm, the following JavaScript error(s) occorred:
At line3365 of file "C:\Programs Files\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\WebAssist\FormBuilder\shared.js": MM.WA_createProcessingOjbect is not a function
Huh? lol I'm totally lost....
Here is where the form can be found: photoform.php
anonymous
Jeremy,
A couple of things to start diagnosing the issue...
One, I would definitely use "Post" in this situation rather than "Get". The Get method sends the variables through the URL Address which is very insecure.
Also, when your form starts to process, it tries to go to "photoform.html". I am guessing you would want the processing stuff on the same page as your form which is "photoform.php". Note - the extension difference (PHP as opposed to html). So you will probably need to correct that first.
The next question to help you get going is what do you want the form to do? Do you want to populate fields of a database or, instead, email someone with the inquiry?
Best regards,
Brian
jeremydavies390881
Email...
Thanks for the reply.
How do I change it to php instead of HTML?
And I'm trying to make it go to my email. I have the Email thing set up (I hope properly) already.
anonymous
To change it to php, there is an option in the Form Builder dialogue box - at the same place it asks you what method to use, it will specify the page. Somehow, your page extension got switched from php to html... you just need to get that fixed and then you should be on your way.
jeremydavies390881
Error?
Alright, I changed it back to php, but when I click Finish, the While executing onClick in... error comes up.
anonymous
Did you post the edited files to your site? When I try your form, it still tries to go the HTML extension, so I cannot see what is happening live on the site.
The other question I have is are you sure the CSS Form Builder folder and its contents have been uploaded to your server?
Cheers,
Brian
jeremydavies390881
No
I'm not able to post the updated files because I'm not able to click finish when I switch action page to the php page instead of the html page, because of that error.
The error that I'm getting now, is in dreamweaver, not online.
And as far as I know, I've uploaded all the files/folders.
anonymous
I gotcha... it sounds like there is something corrupt on that page... just for kicks and giggles, can you creates a new php page and just add a simple form that will process on the same page? If you still have the problem, then there is something wrong with your extension/dreamweaver. If all goes well, it is a sign that you will probably need to re produce your entire form from scratch.
Best regards,
Brian
jeremydavies390881
Still an error...
Alright, I went to create a new php page with just a standard Contact form (pre-built) and I got this error when I click Finish:
While executing onResize in WA_SiteTools_Progress.htm, the following JavaScript error(s) occurred:
In file "WA_SiteTools_Progress":
refreshUI is not defined
Should I try re-installing CSS Form Builder?
And then, when I click Ok, the original error comes up.... :(
anonymous
Yes... you definitely need to reinstall... there is something not right there. It sounds like a corrupt file of sorts.
Brian
