Postcode restriction
Thread began 10/08/2009 6:08 am by rob75685 | Last modified 10/08/2009 5:30 pm by Eric Mittman | 801 views | 1 replies |
rob75685
hi there
Is it possible to restrict or validate the postcode entry to certain regions only ?
For example: to contain GL50, GL51 or GL52 ?
Thanks for your help
This type of restriction is not a part of the zip code validation. However you could make use of the regular expression validations to accomplish this. To get some more info about using the regular expression validation please check the help documentation, there are some examples of how to craft the expressions.
The idea is that you would use an expression that would match the pattern that you are allowing or denying and use that validation to trigger a message to the user letting them know what the problem is.
