error message confirm page
Thread began 4/09/2009 5:40 pm by jamesbal253688 | Last modified 4/12/2009 5:45 pm by jamesbal253688 | 3083 views | 7 replies |
jamesbal253688
i set up shipping with UPS and i get this error going to the confirm page?
Fatal error: Call to undefined function curl_init() in C:\vhosts\markwatsoncarvings\WA_eCart\WA_eCart_UPS_PHP.php on line 69
thanks for your help,
jim balthrop
You need to enable the CURL library in your php.ini file in order to communicate with third party providers like UPS and most payment gateways.
jamesbal253688
thanks Ray
i enabled my curl setting in php.ini, but still get the error
here is my code producing the error on the confirm page. where did i go wrong?
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "LBS"; $Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "4";
i don't have a weight in my database for each item, but the package is the same weight for all items- 4lbs
thanks
jim balthrop
if you get the error: Call to undefined function curl_init()
that means the curl library isn't installed properly
jamesbal253688
thanks Ray
i changed the code on line 69 to this
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".$markwatsonCart->DisplayInfo("TotalWeight") ."";
i don't get the error now but get the message from page
/shipping_failure.php
'We're Sorry
No Packages to Ship"
jamesbal253688
when i run phpinfo() from this page
test.php
open_basdir has this under Local Value
var/www/vhosts/markwatsoncarvings.com/httpdocs:/tmp
if i could figure out how to change that to 'no value', i think it would solve my problem.
any suggestions?
thanks
jim balthrop
jamesbal253688
i couldn't get my host tech support to figure out how to change my PHP core local value for open_basedir to no value
so i tried this code at the very top of my products page
ini_set('open_basedir','off');
It Worked!
here is my very first shopping cart with WebAssist eCart4
www.markwatsoncarvings.com
jim balthrop
jamesbal253688
i found out that the code was not what had overcome the open_basedir errors.
in the file, domainCart_PHP.php
on line 2
require_once("WA_eCart/WA_eCart_Definition_PHP.php"); //this is correct
require_once("WA_eCart_Definition_PHP.php"); //this is wrong
