Server Variable Variable Member ID
Thread began 10/07/2009 3:21 pm by info271221 | Last modified 10/09/2009 11:11 am by Eric Mittman | 1984 views | 4 replies |
info271221
I want to pass the server variable in for the logged in member so that when they click on Update Profile from the Members Only page they can access their member id.
It keeps pulling up user 658 when I am logged in as 5.
info271221
OOPS, Here is my zip file
Please help! Thanks
On the login page are you storing the id for the current user in a session variable? If you are using Security Assist this would be in the last page of the server behavior for Authenticate User.
With the session variable being set over here you just need to filter your recordset for the users on this variable when they go to the update page. On the current update page members_directory_Update_profile it looks like you are filtering the recordset on the URL parameter for id, you should update this to filter on the session variable from your Authenticate User server behavior or wherever the session variable comes from.
info271221
Member Update Profile
Here is the statement on the profile page which is the page that we want to pass the id into from the members_only.php
You can log in with waTest / waTest to test.
member_directory_Profile.php
$Paramid_WAATKmemberdirectory = "-1";
if (isset($_SESSION['id'])) {
$Paramid_WAATKmemberdirectory = (get_magic_quotes_gpc()) ? $_SESSION['id'] : addslashes($_SESSION['id']);
mysql_select_db($database_wibuckbear, $wibuckbear);
$query_WAATKmemberdirectory = sprintf("SELECT * FROM member_directory WHERE id = %s", GetSQLValueString($Paramid_WAATKmemberdirectory, "int"));
$WAATKmemberdirectory = mysql_query($query_WAATKmemberdirectory, $wibuckbear) or die(mysql_error());
$row_WAATKmemberdirectory = mysql_fetch_assoc($WAATKmemberdirectory);
$totalRows_WAATKmemberdirectory = mysql_num_rows($WAATKmemberdirectory);
I have zipped and attached the members, security assist folders and the members only page.
Thanks!
This query looks good to me, so long as you are storing the currently logged in users id in a session variable called id then this should work. You would set this variable in your authenticate user server behavior on the login page. I did not see any attachments to your last post. If you are still having trouble with this please post back with a copy of the login page.
