Fatal Error message in eCart Checkout
Thread began 10/06/2009 10:12 am by Doyleja368034 | Last modified 10/06/2009 8:03 pm by Doyleja368034 | 1049 views | 4 replies |
Doyleja368034
Using the "How To Apply Login/Register functionality to your Checkout Process" guide I have been attemping to implement this feature.
When testing on local server I get the following error message;
Fatal error: Call to undefined function wa_auth_rulepasses() in C:\vhosts\jamesdoylephoto\Bookings\checkout.php on line 10
I've attached the checkout page for your reference.
Thanks for your assistance.
checkout.zip
edit lines 9 - 14:
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("../Registrations/users_LogIn.php?checkout=1");
require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
Doyleja368034
Error message after inserting your code in checkout.
Hi Jason,
Thanks for the assistance. I replaced the code with what you provided and now I am receiveing an error message as follows;
Warning: Cannot modify header information - headers already sent by (output started at
C:\vhosts\jamesdoylephoto\Bookings\checkout.php:10) in C:\vhosts\jamesdoylephoto\WA_SecurityAssist\Helper_PHP.php on line 67
I've attaced the two files for your reference.
Helper_PHP.zip
checkout.zip
There is a space at the end of line 9 of the checkout page that is causing the error:
"<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?> "
remove the space at the end of line 9:
"<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>"
Doyleja368034
thanks
Thanks Jason that solved it!
