Universal Email with Digital File Pro 1 uploaded attachment
Thread began 10/05/2009 10:51 pm by julie.wolpers133706 | Last modified 10/14/2009 11:55 am by jkw133706 | 3057 views | 8 replies |
julie.wolpers133706
I am using Digital File Pro 1 for asp with Universal Email 3.0.6 to upload a resume to the server and also email it as an attachment and the file is getting uploaded to the server but I keep getting this error:
Server.MapPath() error 'ASP 0172 : 80004005'
Invalid Path
/jobs-test.asp, line 42
The Path parameter for the MapPath method must be a virtual path. A physical path was used.
Line 42 from the file has this code in it:
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr( Server.MapPath(WA_DFP_UploadStatus.Item("WA_UploadResult1").serverDirectory) ) & "/" & cStr( Server.MapPath(WA_DFP_UploadStatus.Item("WA_UploadResult1").serverFileName) ) & "")
I am following the instructions in:
dfp_universal_email_attachments.pdf
Thank you!
In asp, universal email gets the server path for you, so it is not necessary to use the serverDirectory binding.
change:
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr( Server.MapPath(WA_DFP_UploadStatus.Item("WA_Upload Result1").serverDirectory) ) & "/" & cStr( Server.MapPath(WA_DFP_UploadStatus.Item("WA_Upload Result1").serverFileName) ) & "")
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr( Server.MapPath(WA_DFP_UploadStatus.Item("WA_Upload Result1").serverFileName) ) & "")
jkw133706
Getting a new error
Thanks. Did that, but now get this error:
Microsoft VBScript runtime error '800a01a8'
Object required: 'WA_DFP_UploadStatus.Item(...)'
I guess I'm doing something else wrong!
Probably the Image upload code is after the email code.
Send a copy of your page in a zip archive so I can examine the code.
jkw133706
thanks, here's the file
Zip file attached.
jobs-test.asp.zip
there is a space in the code causing the error. My fault, I should have put the code correction in code tags.
change:
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr( Server.MapPath(WA_DFP_UploadStatus.Item("WA_UploadResult1").serverFileName) ) & "")
jkw133706
thanks, new error
Thank you so much. I think we're getting closer! The file did get uploaded but I got a new error, I think because the email portion of the script is not able to find the file so there is some kind of path issue. I've attached the file with your corrected code here, and this is the new error message:
CDO.Message.1 error '80070002'
The system cannot find the file specified.
/WA_Universal_Email/CDOSYS_VB.asp, line 11
jobs-test.asp.zip
Use:
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr( Server.MapPath("/assets/uploads/" & WA_DFP_UploadStatus.Item("WA_UploadResult1").serverFileName) ) & "")
jkw133706
Thank you, that worked!
I appreciate your help!!! Thanks.
