No Menu In iE6
there is no MENU in the iE6. Whats wrong here?
index.php
Denis
index.php
Denis
In most cases if there is a problem in IE6 it is because of a bad path to the IE6 conditional css. Since conditional CSS is placed in a comment, the location is not updated by Dreamweaver when a page is placed in a subdirectory or comes from a template.
In this case you need to update:
"../CSSMenuWriter/
"../../CSSMenuWriter/
anywhere it occurs (specificaly for the ie6 conditional code where it is wrong).
Not so good, when using DW Templates :-(
It is still not WORKING. I dont use width, caus I do it via PADDING, so I got always the same space between linktext and next link.
contact.php
Cheers
Denis
I usually add the ie6 conditional code to the header editable region and then update it on each of the pages derived from the template.
