HTML Editor 2 Irite2
Will this be fully compatible with IE8 and the newer browsers under windows 7?
stephen
stephen
Stephen,
It should be compatible with IE8 since it is the latest release of FCKeditor... but I know from experience, that FCKeditor's latest version still has issues on Apple Safari, regardless of the Operating System, so even with Windows 7, Safari may experience issues with FCKeditor.
For example, the latest version of FCKeditor seems to compress the area of the content and it creates a scroll bar - so even though your actual edit area may be sever pixels high, it will make a scroll bar about 100 pixels tall and all the content is viewed within that 100 pixels while scrolling. Now, I have seen where if you wait a little bit - anywhere between 10 and 30 seconds, the javascript takes hold properly and the content fills in and uses the entire edit area.
The other issue I have seen on Safari is that objects (such as images) are not selectable in the edit window, so you cannot resize images on the fly in the editor. I have had this problem with not only FCKeditor but also other editors such as TinyMCE and the newest CKeditor.
As far as if there will be any issues with Windows 7, I believe WA has stated that since Windows 7 has not been released, no testing has been done. But they have stated they would be quickly issuing compatibility releases as needed.
Best regards,
Brian
