How to get results in a grid?
Thread begun 8/10/2024 10:30 am by Peterson Design Studio - jefferis | Last modified 8/15/2024 10:07 am by Patrice | 326 views | 3 replies |
Hi folks, I believe when I created this page they were in a grid. Now they are displayed as a column
html:
https://www.ringsbychristianbauer.com/weddingrings.php
Any idea how to get this page to function again as a grid? It was developed a long time ago, and I forget all I did to create it
<table border="0" cellpadding="0" cellspacing="0" >
<tr>
do { // horizontal looper version 3
<td width="146" align="center" ><form action="form.php" method="post" enctype="multipart/form-data" target="_self" />
<input name="image" type="image" value="value" src="/thumbs/<?php echo $WeddingRings->getColumnVal('Images'); ?>" alt="<?php echo $WeddingRings->getColumnVal('Left_or_Top_Description'); ?>" width="150" height="150" border="0" id="WeddingRings" /><br />No: <?php echo $WeddingRings->getColumnVal('Left_Number'); ?>
<input name="img" type="hidden" value="<?php echo $WeddingRings->getColumnVal('Images'); ?>" />
<input name="Leftno" type="hidden" value="<?php echo $WeddingRings->getColumnVal('Left_Number'); ?>" />
<input name="Leftdesc" type="hidden" value="<?php echo $WeddingRings->getColumnVal('Left_or_Top_Description'); ?>" />
<input name="Leftdim" type="hidden" value="<?php echo $WeddingRings->getColumnVal('L_Dimensions'); ?>" />
<input name="Rightno" type="hidden" value="<?php echo $WeddingRings->getColumnVal('Right_Number'); ?>" />
<input name="Rightdesc" type="hidden" value="<?php echo $WeddingRings->getColumnVal('Right_or_Bottom_Description'); ?>" />
<input name="Rightdim" type="hidden" value="<?php echo $WeddingRings->getColumnVal('R_Dimensions'); ?>" />
<input name="Ourname" type="hidden" value="<?php echo $WeddingRings->getColumnVal('OurName'); ?>" />
<input name="CurPage" type="hidden" value="<?php echo curPageURL(); ?>" />
</form></td>
$row_WeddingRings = mysqli_fetch_assoc($WeddingRings);
if (!isset($nested_WeddingRings)) {
$nested_WeddingRings= 1;
if (isset($row_WeddingRings) && is_array($row_WeddingRings) && $nested_WeddingRings++ % 3==0) {
echo "</tr><tr>";
} while ($row_WeddingRings); //end horizontal looper version 3
</tr>
</table>
$WeddingRings->moveNext();
$WeddingRings->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
?></div>
<div align="center"><table border="0" align="center" cellpadding="0" cellspacing="0" id="repeatnav">
<tr>
<td colspan="5" align="center"><img src="/images/images/spacer.gif" width="250" height="1" alt="spacer" /></td>
</tr>
<tr>
<td align="center"><?php if ($WeddingRings->PageNum > 0) { // Show if mysqli not first page ?>
<a href="<?php echo $WeddingRings->getFirstPageLink(); ?>" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('videobut_r1_c1','','plugins/images/videobut_r1_c1_f2.gif',1);"><img name="videobut_r1_c1" src="images/videobut_r1_c1.gif" width="42" height="13" border="0" id="videobut_r1_c1" alt="First" /></a>
<?php } // Show if mysqli not first page ?>
<?php if ($WeddingRings->PageNum == 0) { // Show if mysqli first page ?>
<img src="/images/videobut_r1_c1_f2.gif" width="42" height="13" alt="spacer" />
<?php } // Show if mysqli first page ?></td>
<td><?php if ($WeddingRings->PageNum > 0) { // Show if mysqli not first page ?>
<a href="<?php echo $WeddingRings->getPrevPageLink(); ?>" onmouseover="MM_swapImage('videobut_r1_c3','','plugins/images/videobut_r1_c3_f2.gif',1)" onmouseout="MM_swapImgRestore()"><img name="videobut_r1_c3" src="/images/videobut_r1_c3.gif" width="41" height="13" border="0" id="videobut_r1_c3" alt="Previous" /></a>
<?php } // Show if mysqli not first page ?><?php if ($WeddingRings->PageNum == 0) { // Show if mysqli first page ?>
<img src="/images/videobut_r1_c3_f2.gif" width="41" height="13" alt="spacer" />
<td align="center"><?php if ($WeddingRings->PageNum < $WeddingRings->TotalPages) { // Show if mysqli not last page ?>
<a href="<?php echo $WeddingRings->getNextPageLink(); ?>" onmouseover="MM_swapImage('videobut_r1_c5','','plugins/images/videobut_r1_c5_f2.gif',1)" onmouseout="MM_swapImgRestore()"><img name="videobut_r1_c5" src="/images/videobut_r1_c5.gif" width="35" height="13" border="0" id="videobut_r1_c5" alt="Next" /></a>
<?php } // Show if mysqli not last page ?>
<?php if ($WeddingRings->PageNum >= $WeddingRings->TotalPages) { // Show if mysqli last page ?>
<img src="/images/videobut_r1_c5_f2.gif" width="35" height="13" alt="spacer" />
<?php } // Show if mysqli last page ?></td>
<td align="center">
<a href="<?php echo $WeddingRings->getLastPageLink(); ?>" onmouseover="MM_swapImage('videobut_r1_c7','','plugins/images/videobut_r1_c7_f2.gif',1)" onmouseout="MM_swapImgRestore()">
<img name="videobut_r1_c7" src="/images/videobut_r1_c7.gif" width="37" height="13" border="0" id="videobut_r1_c7" alt="Last" />
</a>
<img src="/images/videobut_r1_c7_f2.gif" width="37" height="13" alt="spacer" />
<td>&nbsp;</td>
</tr>
</table>
PatriceWebAssist
What is this?
I see you are using:
PVII CSS Page Builder Magic 2
Are all the related files uploaded for that package?
Al Sparber has passed away and P7 Forum is no longer functioning, but Gerry is doing one-on-one help, so if you email him, he may be able to spot the issue too: support@projectseven.com
PatriceWebAssist
ah... the looper is a VERY old Tom Muck extension. I remember that from a zillion years ago. I doubt you need it with newer css coming into play.
Suggestion: Create a simple page without a form etc. Create a div that is 100% of the page. Within that div, create a new div (named something so you can id later for phone) at 25%. Enter an image, text etc. Tie all to database table as appropriate. Then envelop the 25% div and do a repeat region. It should put all in rows of 4 images. (25% will give you 4 to a row, 20% will be 5 to a row etc.) Add media query for phone size to show that name div for 100% etc.
The 25% div will need a class. In the media query for phone change class to read 100%.
Thank you!
