IRite error when inserting image
Thread began 10/04/2009 8:24 pm by mfpena148189 | Last modified 10/07/2009 5:01 pm by Jason Byrnes | 1736 views | 3 replies |
mfpena148189
I created a new page and inserted IRite, when I try to insert an image I get the error described in the attached screen capture. Please note that the error refers to a file named connector.php, my developent model is ASP
Regards
Please see the "Allowing image uploading with the iRite text editor" tutorial in the how To section of the iRite support page:
irite/
mfpena148189
Irite Problem when inserting image
Jason, thanks that fixed one problem but it still doesn't work, when I try to inser an image i get the message: " You Have no permissions to create the folder" please see attached screen capture, also after I uloaded the whole WA_irite folder I dont get button bit maps, please see attached screer capture
Thanks for your help
Manuelp
The permissions error point to a problem with the ConfigUserFilesPath setting.
this path is site relative to the folder the files should be uploaded to to. for exmple, if the images should be uploaded to:
set that to:
ConfigUserFilesPath = "/userfiles/"
Also make sure that the permissions on the userfiles/ folder at:
userfiles/
allow for write permissions for all users. You may need to create the Image folder manually inside the userfiles folder.
For the problem with the icons, edit the iRite instance, on the general tab, make sure a skin is selected, then click OK and re upload all of the files.
