4.5.2 still NOT working with RECORDSET!!!!
MAKE THE UPDATE WORK WITH RECORDSETS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It takes hours to deinstall the old version, and the NEW didnt make iT!
please TEST before RELEASE!!!!!!!!!!!!!!!!
It looksl like the error you are getting rite now is not the same error from the recordset issue and may be a new issue or some other problem on the page. Is this recordset working with any of our databases or your own? I would like to reproduce the problem with the data and page you are using to get a better idea of what is going on here. Please post back with what details you can and I will check it out further. If needed I can open a ticket for you to exchange personal files.
Hi Eric,
Jimmy opend a TICKET 108790.
I updated and then I could place the ad-to-cart-button, but as you can see, there is no ID shown in the select box.
Cheers
Denis
It looks like Jimmy has updated the ticket with a new file for you. Please post back to your ticket if you are having any further trouble with this so that Jimmy can take a look.
