Default address not saving or applying
Thread began 10/03/2009 12:29 pm by jan195010 | Last modified 10/07/2009 5:04 pm by Jimmy Wu | 2134 views | 4 replies |
jan195010
I have entered a default address but when I click finish on the wizard it is not applying the default. I have 2 addresses on my map. The second is marked * as if that is the default but no info boxes show on load at all. I am trying to get the first address to be the default.
All other changes made in the interface save and apply as expected.
I'm using Dreamweaver CS3. Is there any other way to get the info box to show?
I have also noticed that the pdf links in your solution recipes all link to the driving istructions pdf.
Thanks in advance.
Jan
Jimmy Wu
Do you have a URL where I can see this issue?
jan195010
Hi
Currently here:
find-us.php
Jan
jan195010
update
Asan update this still doesn't save but if I delete and reenter the address I want as default so that one info box is open the other address disappears. Is this a known issue? If so how can I apply for a refund as this gives less functionality and is currently causing more problems and taking more time than embedding a map via the google site.
Any information appreciated.
Jan
Jimmy Wu
Taking a look at your site, it looks like there are two markers put on the map and there is an info window showing up for Springwood Ground Hutton. I'm not sure if you've made changes since your post to make this work. If you want the info window text to show something different, on your page you can modify the:
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><strong>Jubilee Ground</strong></span>',
to be what you want displayed. This will be done in the google_javascript/wagmp_map_[map_num].php file in your site.
